Thanks for the info, I already tried connecting with putty which is an alternative to the old hyper terminal which I remember well in windows xp. "putty is shown in your link", with puty I can easily add a serial device and set it com 2, 9600 bps, DATA 8-bit, STOP 2-bits, PARITY none, XFLOW On BUT I just get a blank screen and if I type a command I just get question marks. I must be missing something very basic because the ability of connecting to the radio is working fine as arc8600 and aorctrl software connect ok to the serial port. the AOR manual doesn't give any further info they just show the list of commands not the method of connecting.
I received a message from AOR "shown below" but it doesn't mention the serial terminal method. I tried what they told me on the radio itself but it freezes, I did say I would send the radio to them but they think its just a matter of clearing all the memories. If I could just learn how to connect via terminal I might just be able to clear out the defending corrupt data.
Message from AOR
If AR8600 is behaving strangely such as locking up or powering down unexpectedly, it may be suffering from corrupt data (programmable data or system data or both) due to a power glitch (a.c. supply interruption, battery low etc).
The corruption can affect the search bank, memory bank (or channel) or indexes such as pass list of select scan list. Instead of the data reading (for example)123.450 MHz, it will attempt to read 123.zv0 MHz... as the corrupt data is not recognised, it causes the AR8600 to 'crash'.
Try deleting & over-writing search banks, pass lists, select scan lists etc.
AOR Japan.
