FD enroute to a call: Uhh dispatch, can you call PD for (pauses)... animal mitigation? Theres several deer at (location) running back and forth across the road, causing traffic to back up.
Heard a call today, Dispatch very clearly stated all the info, including which radio channel to use. Every truck (3 total) that went to the call had to ask for the ops chan. And they were staggered out. I take it they dont listen much to their own radios.
Fire? Might have been volunteers that weren't at the station yet when the call info was given. I was a volunteer firefighter in the 90's and all we had were pagers (and the firehouse whistle) to tell us a call came in, wouldn't know where or anything else until we got to the station unless we happened to be listening to a scanner when the call came out, rarely did all apparatus go out at the same time.
Na weve all newer voice pagers that states what the call is, where, ops chan, and type of response.
Everybody around here has pagers that record and can play back the info at will and as many times as you need to fix it in your mind (such as for those notorious 0300 calls) but I am constantly amazed at the number of, "Can you repeat those numerics? And do we have a Fireground assigned?" calls back to Dispatch.:roll:
I wasn't trying to be contentious, just commenting that sometimes all that "fancy stuff" might as well be left in the box. I get it, I really do...it's a people problem, not a technology problem.:wink:Waaaaay back when I was in fire service we had a beeper type pager, not all the fancy stuff they have now. The beeper and the firehouse whistle is how we knew to respond, once at the station you called fireboard for what's up.
That's why I responded the way I did above.
Albany Police to Dispatcher investigating a possible water main break:
“Notify the water department. Also, contrary to what the caller said it’s not flowing like a river, more like a stream or small tributary.”
