G-5 alert beep
Clarky
N/W Florida
When my G-5 pager is monitoring a radio transmission, I receive a loud beep when they stop talking. Can this be turned off? I spoke with my vendor, however the programmer wasn't familiar with it.
Thank you in advance.
kruser
Well Known Member
W St Louis Cnty, MO
When my G-5 pager is monitoring a radio transmission, I receive a loud beep when they stop talking. Can this be turned off? I spoke with my vendor, however the programmer was familiar with it.
I've never heard this on my G5.
Do you have another radio or scanner you can monitor the system with to see if this beep is also present on that radio? It could be something setup in the system. I kind of think this may have been brought up before though so it could be a setting in the PPS software. I can definitely see where it would be annoying!
Clarky
N/W Florida
My G-5 has a channel set up to monitor fire traffic. When someone keys up on a P25 Phase II system (700 mz trunking) there is a loud beep. I can play it over the phone with the use of a Motorola APX-6000. My number is (850) 384-5490. Thank you.
Clarky
N/W Florida
Aaron from Unification was able to help me.
Under program #7 (Pager configuration settings) un-check "unread message reminders".
