G-5 reception issue on patched TG
Listening to my G5 and TRX-1, the TRX-1 is picking up a patch from one TG to another, but when the scanner shows "patched" my G5 sits silent. Both the TGs are programmed in and work fine when they are not patched.
Have the most current firmware and PPS.
Am I missing a setting?
mkinkade
Central Ohio
I recently saw a similar issue with a patched talkgroup on the OH MARCS system. My Uniden scanner was receiving the communications on the patched talkgroup. However, my G5 was silent. G5 could hear the traffic on the original talkgroup that it was patched from, just not the one it was patched to. I've seen other patches that it handles fine.
I'm also on the most current version.
Giddyuptd
Here and there
Seems like a firmware bug. There are others I've noticed as well including dmr scanning
Giddyuptd
Here and there
Being technically new still I'm sure they'll eventually address bugs. But it is important for those to document and have dealers inform them to address them.
I haven't had the tg patch issue yet but like I said I noticed issues with dmr scanning, analog using mdc and missed traffic, csq misses traffic sometimes but on a g5 vhf is a sub band so it is possible this is normal for that. I couldn't say on a vhf only unication if those issues exist.
In end a lot is settings which can be addressed by them in making things more clear or allowing more thresholds such as dwell times and scan resume or hold times in conventional use or syatem specific in the pager.
While it may seem irrelevant to the scanner users on a system some of this is important as it I'd marketed as a pager and receiver for official use.
I'm on fence atm on getting more but in time things may change if they address some issues. This is important if a entity is using vhf/700 or will be.
I have confirmed that many issues exist are firmware or engineering bugs that possible could be worked out by them. Being new still I think they have a lot potential if firmware updates occur specially with talkgroup patch issues.
I'd give them time as they probably try to address many issues Ina. Release but must test verify before releasing those as all on one seems to be the firmware path they do.
FishScan
Harris or Motorola system? I don't think the G 4 or 5 is considered a new device. They've been around for at least 5 years.
