G.E. 3-5819B no tx or receive
lugnuttz
utica n.y.
i got this radio today and it lights up...the modulation light shows that i am talking into the mic but the meter doesnt move when i key up...and the radio doesnt transmit...also there is no sound from the speaker. the needle doesnt move when i key up my base .it does not recieve
whats wrong with this thing ??
microphone wiring
The first thing I would do is check the mic wiring. not wired wrong but a broken wire in the mic or connection. Sounds like the rx and audio wires could be broken. that is one of the most common problems with cb's .
lugnuttz
utica n.y.
365 thanks for the reply....i will def check that but i did try another known good mic and had the same results and when i key the mic whether it be the original one or the known good one it does acknowledge that the mic is keyed because it makes the modulation light come on. when the mic is keyed... but thats the only thing that happens
any other suggestions i have looked at the circuit board and there doesnt appear to be any damage or any sign of a component being fried or damaged in any way
westbound
Fort Payne AL
If you have a good ant.and ground plane,ck your swr,but if all that is good your finals are probaly blown. you will need to take it to cb shop .Good luck,westboud-out
