G-Series Message Backup Software
I have the Unication message backup software installed on my PC, does anyone know how to download the audio in an mp3/WAV format?
Try the following and see if it works for you.
  • Open the G Series Message Backup software.
  • Select tab “B Backup.”
  • Select “Backup.”
  • When the message box “Message Backup Finish” is displayed, select “OK.”
  • Select tab “D Export.”
  • Select “Search.”
  • Select “Export All File.”
  • Browse to a folder or, if a new folder is desired, select “Make a New Folder.”
  • Select “OK”
  • When the message box “Confirmation” is displayed, select “Yes.”
All the audio files (in WAV format) and the associated text files will be transferred to the chosen folder.
You can then use your media player of choice to play the audio in sequential order or individually.
To play in sequential order using VLC media player:
  • Windows 10: Right-click on the folder containing the audio files and select “Play with VLC media player.”
  • Windows 11: Right-click on the folder containing the audio files, select “Show more options,” and select “Play with VLC media player.”
