G1 not toning out on monitor
Ericsloan
G1 not toning out on monitor i can not remember if it is suposed to. and a second question is is there a way to tes the pager without having county ?
RBMTS
That is a difficult question to answer without looking at the setup. Is this a department pager or do you own it? If you own it, look at your setup with the PPS to view how the switch position is programmed.
No. Again, if this is a personal pager, add in a switch position for a department that has frequent calls (say EMS tones) so that you can hopefully receive more frequent pages to see if you are setting up the pager correctly. Regardless you need on-the-air tones to activate the pager.
