G3/G5 False Out Of Range Indication
tglendye
Blue Ridge Mountains, Shenandoah River
Are you all still having this issue? I am on 1.4, not 1.3. I don't have the PPS with me, but I remember running into this problem before. Is your site trunking box selected? My issue was I selected that box when I was in the program one time. I removed the check mark and it went back to normal. I remember reading this box is normally not supposed to be checked.
dbodette
Wauseon, OH
Update on the out of range problem I was having. I'm not sure what exactly happened but one day it was working great and the next it was not hardly picking up any signal. It appeared that it was somehow related to the 1.3 version upgrade since I had done that only a few days prior. I sent it in to Unication describing the issue as a sensitivity problem as the unit was still under warranty. They returned the unit with the explanation "internal antenna adjusted" and now the unit is working perfectly just as it did before. I'm not sure how this relates to the issue as I thought the internal antenna was for the VHF and the rubber duck was for 700-800. Irregardless, we're back to normal!
dbodette
Wauseon, OH
I have no idea. Not sure how it could unless you push something down in there on purpose. All they said was they adjusted the internal antenna.
MPFD535
NJ
I was searching the forums for this exact problem, I have multiple G5s and they will randomly go out of range when they have 3 or more bars. It has done it a few times with full bars, it does it a lot more with around 3 bars. At first I thought maybe it was my portable de sensing it, but I have been leaving the radio off and it still goes out of range and then comes right back. I am monitoring a simulcast 700 MHz system. It acts like maybe its checking for a stronger control ch from another site, but i dont have another site. Anything in the programming anyone could recommend I look at, maybe I missed something, I have only the 1 site programmed and its 4 possible control chs.
Thank you !!
IAmSixNine
Dallas, TX
are you near a Verizon tower? Their low band 700 stuff has ben known to cause interference on the G4/G5 units. I know of 2 places that i can drive near and full bars goes to out of range then back. Even though its receiving the system the error rate gets so high it looses lock and looks for a new site. At least thats a simple explanation.
