G4 doesn't turn on
Mendykj
Hi, my Unication G4 doesn't turn on and lights up 3 led when changing
lebrunmn
Retired... Get off my lawn!
Hampshire County, WV
You should try pulling the battery out, waiting a few mins, replace the battery, then try to charge it again... There should be other threads about this on RR.
Good luck.
IAmSixNine
Dallas, TX
That happened to me when the battery was completely drained. I left it plugged into the wall charger and after a while came back to life.
You may also want to try a battery pull if you know for sure the battery was charged.
Mendykj
So, I tried this battery in a different pager, and it works, versus when I tried a working battery in the mentioned device, I had the same issue.
Did you leave the battery out for about 5 minutes, or did you quickly change the battery?
Mendykj
I changed quickly, but I tried now twice leaving it out for 5 mins and still no change. I doubt it's battery related related because A: The battery is in good condition and charged when in a different pager. And B: The LEDs will light up when plugged in to charger even with no battery installed.
blackbelter
Per my previous posts, I had the same issue with my G5. After resetting the battery as well as the pager and cleaning the charging contacts( both the pager and the amp charger). Unication repair determined that the processor was the issue and replaced it.
