G4/G5 Programming Question
tvengr
Well Known Member
Baltimore County, MD
Does anyone know if there is a way to copy and paste or use csv files to enter multiple frequencies and talkgroups in the G4 and G5 PPS without having to do them one at a time? Thanks!
bob550
Albany County, NY
With a Premium Membership through RR, you can download and import CSV files for P25 trunked talkgroups into PPS. Using an appropriate CSV editor, such as MS Excel, you have the option of sorting talkgroups and changing alpha tags to your liking before uploading to PPS. The import option is found in PPS section D4, Group & Group Call ID Setting.
APX8000
Sarcastic Member
AES-256 secured
Can someone post up a .csv file for import so I can take a look at the parameters? I want to edit my current list
tvengr
Well Known Member
When you hit Import, it goes to the RR database. I don't know if there is a way to import your own CSV file.
AdamHLG
I have also been playing with this trying to import some data and I created my own file (and I even tried your file with same result), but when trying to import the data into the PPS D-4 group list, it says "the data format of this file is incorrect".
bob550
Albany County, NY
Try this one. I found the original file had been missing the column headers and attempting to import gave me the same error. I verified the file now imports with no errors.
  • Metro Cell.zip
AdamHLG
Success! Thank You!
APX8000
Sarcastic Member
AES-256 secured
Same, thanks Bob! FYI, I played around with the file...the only two fields that need entries are Decimal and Alpha Tag. The headers must be there but the entries in those colums can remain blank.
bob550
Albany County, NY
Now, depending on your location, all you need is a 2,000 ft. tower and 800MHz yagi to monitor Albany NY PD. Careful though, it's not the most exciting monitoring around. Doing so may cause drowsiness! :LOL:
