G4 or G5 audio
blackbelter
Thinking about purchasing one and curious about the quality and the volume. How would you compare it to a pro unit like a Motorola HT? It will be used in a noisy area with no headset .
Casey
East Cobb County GA
I have a G4...it's an absolute little wonder...BUT I suspect you will be disappointed with the volume if you wear it on your belt in a noisy environment not using a compatible bluetooth headset or not purchasing the amplified base for stationary use.
