I've been a user of monitor/scanner radios since 1971. I have owned many over the years, and still have a four channel Regency and a Bearcat 101 (which just finally surrendered). They all provided good service until the 800 mhz digital trunking began. My current radios are a Radio Shack Pro197 and a Uniden 536. I just can't take the frustration anymore of the garbled transmissions and have the funds to get a better radio. Both of my current radios work well enough to receive the original fire dispatch transmission. I need to monitor both Carroll and Baltimore Counties in MD (digital 800 Trunking), and do so using either/both the Carroll high band pager 150mhz or Balto low band 46mhz channel along with the 800mhz trunked band. The trunked dispatch channel usually works ok (mostly), it's the mobile reponse that gets all garbled or is missing entirely. Sometimes over 50% of the entire trunked conversation will be garbled or missed.
I understand that the G4 is not a scanner. I did borrow one for a day. When I heard the dispatch on my current scanner I would then turn it on to the response channel to follow the communication. It worked very well, but not as convenient as just having one radio "do it all". Perhaps having a small G4 would have some benefits (portability, stuff it in my pocket while enroute to the firehouse, use for portable monitoring of dispatch, and so forth).
I would appreciate any opinions on the Uniden sds200. Does it solve this distortion issue? Anyone have any long turn use of either or both can share some insight?
Don't think I'm interested in the sds100. I really like the bigger base units. I had a Uniden handheld once (don't remember the model) Always felt kinda plastic cheap and not too rugged. The G4 seems solid.
Thanks.
Thanks.
