G4 programing question
shfd7
Pike County, Mississippi
I wanted to add one new TG to my g4. I went under the knob selection I wanted the new TG to be in and added it. Now that Knob selection is picking up everything that is coming from that tower. I do have that knob at Trunking TG-scan, and as far as i know the group and group ID call setting is the same The only thing I changed was adding the new TG, and now I'm at a loss.
N6ML
You probably have a group defined with ID 65535 (decimal) / FFFF (hex) - check carefully. If you try to enter a number that is larger than this value, it will change to this value by default. 65535 acts as a wildcard (matches any TGID), and numbers larger than this are not valid TGIDs.
RBMTS
Or you have the “Function” defined as Trunk Sys Monitor (which open monitors all talk groups on that site. Change it to Trunk System Scan for listening to a single talk group (or multiple selected Tg’s you want to listen to).
shfd7
the tg group i was trying to add was DEC: 60000 and ea60 HEX. So it seems like i was in range.
shfd7
I checked that out and the two knobs that I have the most TGs on are set to trunk system scan, but act like they are on Monitor. The other knobs are on scan and only have a few TGs in them and work fine. I even deleted the TG i was trying to add from the group id setting tab.
shfd7
Sounds like you have Monitor set somewhere. What system(s) are you listening to?
I am in Mississippi so its MSWIN. I am listening to only two counties, the one i am in, and the one we usually assist. Only two knobs scan most of both counties. One knob does open monitor. The others are set to my dept only. Every knob, except for the open monitor, is set to the trunk system scan. Everything worked fine until I tried to add the other TG. As far as I can tell, everything is set back to the way it was before the add.
