G4 Random Reception Dropouts
kinglou0
Hopefully Unication Dave is at least reading our posts.
I suspect he's either incredibly busy or he's packing his bags for an escape to somewhere warm and without an Internet connection if Unication doesn't make this latest Phase 2 deadline.
Counting today, 6 business days left in March/Q1 2018.
mdsxfire
EDBM
Uxbridge, north of the river Thames
I don’t have any interest in the phase 2 update so I’m hoping they release a regular firmware update in addition to the phase 2 update. I know many of you have been waiting a long time for phase 2. The Michigan system is phase 1 and if/when they decide to go to phase 2, it will be years before the upgrade is completed. Still going strong without any dropouts since I flashed it. Makes me wonder what hanged in the latest firmware that is causing the bug. Hopefully Unication Dave is at least reading our posts.
I forgot u are in Michigan, well at least u are going good with that version.
mdsxfire
EDBM
Lmao, I think he got sick of these forums and completely abandoned them. I’m ready to pack my bags for somewhere warm with all these snow storms!!
IAmSixNine
Dallas, TX
So it seems as with all the drop out complaints the latest firmware is the culprit. Hopefully the phase2 firmware will address this also
I believe it may have. But again im not monitoring very busy systems or ones that use patches. Good to know R11P is working well for that user who reported issues and now isnt having them.
David_Oney
Former Unication Tech Support
Raceland, KY
We don't have a Michigan separate release anymore. Disable Voice Buffering on the Knob position this should resolve your issue.
DewAddict
Michigan
Thanks For the response..I have flashed the newest firmware once again and loaded the codeplug that goes with that firmware, so far no dropouts. I will report back as more hours pass.
DewAddict
Michigan
I am back to report that it started dropping out once again. I disabled voice buffering on every single knob position and in every zone, as instructed.
Going back to R11P.
Hopeful for a fix.
DewAddict
Michigan
Try moving it away from all other electronics and see if that helps.
It wasn’t near any electronics. I had it sitting on an end table across the room from the TV. All other WiFi devices etc are in my office. Thanks for the suggestion though. I have no issues on this firmware and it works fine for my use.
mdsxfire
EDBM
Do u have any patched TGs programmed? Just reading the other thread here the op seems to have his signal drop zeroed in on when he receives a patched TG.
JSsignal16
I've disabled voice buffering on all of the knob positions in my G5 with the option available. I still get the dropouts. After a few days of trying other things to minimize this I finally decided to setup unitrunker and turn on my 436 and my G5 and try to observe what the trunk system I'm monitoring is doing when the G5 drop signal. After about 2 hours of monitoring trying to pinpoint I finally figured out what is likely causing this to happen. The G5 loses signal every time two or more talk groups in my non-prority scanlist get channel grants simultaneously. Which tends to occur more frequently when a system is busy
JSsignal16
Even if more than one talk group is active as long as none of them get channel grants simultaneously the G5 will never lose signal and will scan between the talk groups without any issue. I think what often happens, when the signal drops after a transmission, is the radio resumes scanning immediately, often before a reply, and when the radio detects the channel grant for the reply, another talk group becomes active at that exact moment leading to the radio losing signal for 5 seconds. I'm not sure if anyone observes this behavior when scanning in priority talk group scan mode. I only have non-priority talk group scan lists programed.
