G5 10 minutes of record
mr1973
I have a channel set for selective call with record. It continues to record fo 10 minutes. It’s set for manual reset. Any ideas?
troymail
Silent Key
Sounds like it is doing what you programmed it to do.
Do you require it to be in "Manual Reset" mode?
There is a "Voice Message Recording Limit" setting in tab D7 which is defaulted to 10 minutes. I suppose you could change that (I've never tried it).
I use "Delay N Reset" and 30 seconds vs. "Manual Reset". On alert, the radio will record up to 30 seconds after the alert (which is usually more than enough time for my needs) and then reset itself.
mr1973
I’ll give it a try. On a minitor it will stop recording on manual reset but the channel will remain open till you press the button squelch button.
mr1973
Looks like revert reset will do the trick. Now i only have to get a call to see what happens.
troymail
Silent Key
I'd actually prefer a simple auto reset vs. a fixed time. However, as the PPS says - the alert and recording will end on a normal auto reset if/when there is a break in the transmission of more than 500 ms (1/2 second)... that just doesn't work for me.... I'd like the ability to configure that 500 ms value - set to maybe 2 seconds and then have the auto reset kick in...
