Hi all,
I have a G5 and an amplified charger. When I have the G5 in the amplified charger and I have the antenna that connects to the back of the charger on the unit, the G5 will not receive any VHF frequencies. May just be a bad antenna.
If I take the antenna off, everything received loud and clear. Obvious when I'm monitoring a P25 system, it uses the radio antenna instead of the back antenna and everything is good.
It's easiest enough just to leave the amplified charging unit antenna off but I was just curious if anyone else also had this problem?
Thanks!
Thanks!
