G5 internal antenna help
ngawx
Holly Springs, Georgia
From reading all of this, I ordered my Amplified charger this weekend from East Coast Pagers. I am hoping to see a improvement for the 1 VHF P25 signal that I monitor inside my home (dont ever have a problem with 700/800).
IAmSixNine
Dallas, TX
Well thats different.
I have 1 at home and 3 on my desk and none have an antenna connector. Im guessing home brew.
Hit_Factor
Saint Joseph, MI
I bought used from a ham on QRZ so I don't know history. I submitted serial number to Unication, said something was irregular, where did you buy it they asked. I answered, but they wouldn't reply.
I really haven't examined it, just figured it is what it is. I'll take a closer look.
radio3353
Are you able to open the unit without damaging it? It would be most interesting to see how it is wired inside. Apparently you have a unique piece of hardware there.
KevinC
Other
Super Moderator
Home
Engineering sample or non-NA market device I'm guessing.
bob550
Albany County, NY
Think of how valuable this will become if Unication decides not to manufacture it! You may have the only one.
nyscan
Also, another difference.. There appears to be a second green LED lit. Only one normally lights.
Hit_Factor
Saint Joseph, MI
Left LED is pager present. Center LED is power present. Right LED is probably alert received, I have alerts disabled and have never seen the LED on. Little bit of a guess on the right LED function.
jeepsandradios
East of the Mississippi
MY gut tells me the basic charger has the pins in the base to the antenna port on the pager but probably not hooked to anything. Back in the MIII/MIV days I found if I added 2 pins to the standard basic charger base and soldered a BNC connector on it It did the same as the amp charger. We were on lowband at the time and everyone wanted an external antenna. Used to sell them the same day at the radio shop. THink it cost us $5.00 and 15 minutes in parts to add the BNC to the back.
Has anyone looked at a basic drop in charger to see if the pins are in the base ? I'd order one to try but 90 vs 130 is close enough not to worry.
