G5 not connecting to PPS Software
neilromesburg
Gambrills, Maryland
My G5 has connected to the PPS software just fine for several years, today I tried to update some software and PPS V0.3.16 Beta24 does not recognize my G5 get No Device Detected Error Message. I'm using the original Unication USB cable that I have always used. I am running Windows 11 but that's all I know that has changed since the last time I programmed my G5. I get a ping when connecting the USB cable to the computer and the G5 shows that it is charging. I see a USB Serial Device (COM8) show up in the Device Manager when I connect the G5 but it does not show up in the Universal Serial Bus devices section of the Device Manager. Any suggestions?
lebrunmn
Retired... Get off my lawn!
Hampshire County, WV
Did you check the Unication download website? There's a link that specifically mentions "If you're having issues connecting to the PPS" or something like that...
There is also another thread that mentions this issue--assuming it's not a Windows 11 thing--check that out, if you like:
Hope that helps.
neilromesburg
Gambrills, Maryland
Hope that helps.
Thank You Mark, I searched the forums but did not find the links you posted. Downloaded the driver from Unication website and it worked. :) (y)
Railbender
NW PA
It should show as a network adapter not a USB device. You probably have a driver problem. Try reinstalling PPS and see if it works. If you are really running Win 11 you may need a new driver, if one even exists.
