G5 not scanning a 700 Phase 2 Harris/Tait system
astrousr
Having an issue with my G5 getting it to track a 700 MHz P25 Phase 2 system, specifically a new Harris/Tait system being implemented for Washington Dept of Transportation.
I have entered the active control channel freqs, WACN and site ID being broadcast verified thru pro96com software and my SDS200 scanner. The system can be tracked with no issues with my SDS200, but when I try with the G5 it just says scanning for several minutes with no signal strength bars then goes out of range.
I am able to scan various 700 and 800 MHz Phase 1 and 2 systems around the Portland metro area with my G5 with no issues at all, in fact the Oregon Dept of Transportation system is also a Harris Phase 2 700 system. I also tried changing the WACN and system ID to wildcard, all F's with no luck either.
The system is still being built which may cause some weird issues, but it can be scanned with the SDS. Also no encryption noted yet, so can't be that.
Any one have any ideas? Thanks
astrousr
OK here it is, I deleted out all the systems and channel positions that I am using and that work and just left the troublemaker system. Like I mentioned this is a system still being built out and so I don't have many talkgroups for it yet, so I just have it in Trunk TG Monitor mode.
I had more control channels in it previously but when troubleshooting I took out all but the ones that I knew were active and in range.
Thanks for checking.
  • WSDOT test.zip
astrousr
WX4JCW
Stow, Ohio
I’m surprised it worked at all without setting them
