G5 nuisance delete ?
fireboat61
DelMarVa
I have gone throughout the G5 pps and haven't found a nuisance delete key option. Now I am curious if I do not know where to look. Does the G5 pps have a function key or allow a button to be programmed as nuisance delete ? Sometimes I am just outside the coverage area but close enough to break squelch. It would be great to have that option of a temporary nuisance delete while in scan mode.
ecarvalho
If traveling I would suggest setting each system in zone position so you can switch to the position of the system you are traveling near by. I don't believe that temp delete feature exists on these pagers.
troymail
Silent Key
Correct - not alot you can do without the programming software other than to switch to a different zone/knob position that you programmed in advance. I found that out when programming some systems/talkgroups for a drive -- many are encrypted and not labeled as such in the RRDB - talk about driving you crazy! It was either turn it off or switch to another zone/knob.
