G5 out-of-range alert question
kc5igh
Velarde, New Mexico
I love my G5, but there's a very minor irritation I encounter now and again with its out-of-range alert.
If I switch to another system while the one I'm monitoring is out of range, the red out-of-range alert will flash on and off while receiving transmissions on the system I'm presently monitoring.
None of this seems to affect the G5's performance, but it is a bit of an irritation.
Advice? Suggestions?
Thanks.
-Johnnie (KC5IGH)
lebrunmn
Retired... Get off my lawn!
Hampshire County, WV
Johnnie-
You could just disable the out of range indication or change the rate at which it notifies you... I usually am constantly checking the signal indicator, anyways, so I could live without it. It's your call.
Good luck.
kc5igh
Velarde, New Mexico
Johnnie-
Good luck.
I like hearing the out-of-range signal, so I'll probably leave it alone for the time being.
As noted earlier in this string, I may want to try updating the firmware.
Thanks!
