G5 PPS update or windows update?
Hit_Factor
Saint Joseph, MI
Not that I'm aware of.
You should be.
Some details about your computer would help. Everything works as it should on mine, with AV software, and all of the Windows updates.
Old files gotta go. Copy them off if you think you need them. Then get rid of everything left behind by the Uninstaller.
trido
Retired
Southern In
I had this happen before,i used free program revo uninstaller deleted all of the pps then reinstalled pps.
Has anything been updated within the last 24 hours. My computer will no longer open up the G5 PPS.
JMR3865
Monmouth County, NJ
I used Revo, opened up the first time and now it will not reopen... UGH. I may run this computer over with the fire truck!
AdamHLG
It might be time for you to save all your data to a thumb drive or cloud, then go through your hard drive and make sure you didn't forget anything (particularly your user folders such as documents, downloads, pictures, etc), and export any files as a backup i.e. quicken, etc., , , and then AFTER double checking again that you didn't forget anything, format your drive and factory restore Windows, and start again. Or if you are due to get a new computer, now may be the time. Last resort of course - but there's nothing better than a fresh clean Windows install to speed everything up and have things run smoothly. It is a lot easier to do this now days then it used to be when reformatting meant package after package of running install DVDs one application after another. Now everything is a simple download.
Hit_Factor
Saint Joseph, MI
I know a lot of people use Revo, but use the uninstaller that came with the program or Windows Add/Remove. Registry cleaners is asking for trouble.
