G5 Questions
peq387ab
Central Minnesota
I have a couple questions with programming a G5
I have a G5 and I’m currently programming a couple more for our department. I did create a code plug for them but when I went to upload it i had to download the latest version. Then when I download the latest version to upload that code plug I created in the old file the G5 programmed all haywire. The first zone I have VHF selective call feature and then 7 800 MHz trunked Trunking TG Normal Scan. But when I programmed it there was stuff completely missing and things duplicated in different knobs they were not suppose to be. Not sure what I’m doing wrong. Does the serial number of what you have to select change now with the newer ones that you purchase?
Serial # of mine I have is AG5V8S0127
Newest ones model # are: G5B67BF-SXVXEN1401UNI-0002-180625.
not sure why I have ran into trouble with this go around. Let me know what I’m doing wrong or maybe missing. Thanks
peq387ab
Central Minnesota
Update, from what I'm running into is I noticed the selective call doesn't show up and shows up unprogrammed. Then when I create two Trunking TG Normal Scans, only one shows up where its suppose to be and then it overrides the other one and duplicates that same zone again. When I uploaded the original code plug yesterday it was the wrong version but now I'm using the correct version.
relicwr
If it's the latest from the website, I've had issues in Windows 10 with that software. I've had to use 7 (luckily in a virtual machine) just to program it. The betas I don't have a problem with in 10.
peq387ab
Central Minnesota
Just giving everyone heads up on what I found. Contacted vendor and their tech support, was out of my control bad pager, there was something corrupted inside the memory of the unit, so I’m getting it swapped with a replacement.
Thanks everyone!
