G5 shuts down and reboots after 1 min.
SafetyGuy
Linthicum, MD
My G5 boots up system comes up get all bars for the system then screen goes blank then the reboot screen comes up. I took the battery out and reinserted. does the same thing. Any ideas how to fix?
cpetraglia
Fairfax, VA
Is it a new pager? Or has it been working and then started doing this? I have heard of different issues, but this ones a first.
krokus
Southeastern Michigan
Does the battery have a full charge?
Sent via Tapatalk
SafetyGuy
Linthicum, MD
Had the pager for a while. This just started happening. Battery fully charged. Can get it to work after it reboots a bunch of times. It will work fine all day then in the morning it has the same problem. I noticed it reboots when audio comes up. If I put it on a empty channel it stays on until I put it on an active channel as soon as audio comes up it shuts down and reboots.
Tim-B
Down South
One thing that came to mind when you said that it happens when audio starts: Clean the battery contacts on both the radio and the battery. When it starts to put audio through to the speaker it uses more juice and if it is not getting enough from the battery it may cause it to go off like it would if the battery was running dead and then because the battery is actually sitll putting out current then it reboots. This may not be it but it is worth checking out.
cpetraglia
Fairfax, VA
I would reload the FW and try a PPS CP with limited entries. You can create a new profile and keep it separate. This will at least tell you if the SW or FW is corrupt. If it continues, it may need to go back for repair.
IAmSixNine
Dallas, TX
Is this system running Phase 2 TG? I recall reading a thread before that someone had issues with their unit when it stopped on a Phase 2 TalkGroup.
Is it possible that the unit is not liking a specific talk group and thus rebooting because it cant decode Phase 2.
SafetyGuy
Linthicum, MD
Nothing to do with phase 2 TG. What is strange is after doing different things with the function mode I can turn it off and on and it works fine. Let it sit overnight and it starts all over again. It only does it when the verbal come up. Place it on a position that I haven't programmed and it stays on. I don't think it has anything to do with the battery because when I finally get it to work it stays on for hours.
