G5 - Tones over P25 Trunking
bamx2
Indiana
My G5 is alerting I believe, because the screen is turning the appropriate color, however I am not getting an audio alert when the tones come in on P25. I've attached some screen shots in case anyone can see what setting I have backwards.
Also, is it only possible to add 1 call alert address into the G5? I am not able to add many?
Webodisk
Silent key.
Virginia Beach,VA
On your talk group you have tone set to none
Sent from my iPhone using Tapatalk Pro, correct only one call alert at this time
jeepsandradios
East of the Mississippi
So i have been trying to get my pager to alert also. What tones do you send out for alerting ? If i use a A/B tone is that a QCII from the console ? Mine is setup similar to yours with tones.
Golson2210
Brooklyn Park, MN
Have had the same issue .. have discovered if you put a tone #, or "default" on the talkgroup channel that the channel alerts with the annoying beep rather than the chosen tone#.
