G5 Trunk system
Com-Tech51H8
bureaucratic absence of presence.
BEE00
Ok im fairly well versed in programming these devices but ive come across an issue i havent seen before. In one zone i have several channels that belong to a specific system programmed on each knob. But the problem I'm having is that it's acting as if there's a wildcard programmed on each knob channel when there isn't. What could I be missing
Sent from my SM-G955U using Tapatalk
Com-Tech51H8
BEE00
Ahhh ok so set it to scan and shhould work fine
LEH
Yorktown, Virginia
When you set a channel in a zone (knob position), you will need to have at least one TG in the channel's TG list. As I recall the PPS will tell you this if you leave it empty. From other comments, the TG can be anything.
