G5 trunked problem
22nineline
Programmed a trunked system into the G5 and I'm getting nothing. Now I have programmed this same system into 3 other G5's I have owned before so I know I just missed something. Did some searching before and found a box I might not have checked but that was a couple of months ago and I did not get the time to go in and try to find it. Now maybe it is this item I forgot or since I got this used maybe something the past owner checked and I just missed it. Any help what it might be?
There are lots of boxes and your post is really vague, I suggest you check the programming between the working 3 G5's and the non-working one. Perhaps rather than getting dozens of possibilities, which may result in no help and a lose of time you say you don't have to diagnosis the problem, just comparing the working code plug and non-working one is the better option.
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
Welcome to the RR forums. What box did you or previous owner forget to check? Specific info goes a long way if you're asking for assistance
22nineline
I did a search before and found something that several people had told the other guy asking about to check and it worked for them. I have searched again and so far have not been able to find that post again. Do not think I have a backup of the code plug I used on the 3 other G5's because that computer died on me and I sold the pagers off. Was just hoping somebody would know what is common to miss when programming the G5. I've been doing some digging but coming up empty for now. I do not think what I found before was on this forum so not sure where it was. Thank you for any help, I'm not asking other to spend their time looking. And no I have not up dated the software in the G5 yet
CanesFan95
Analog already is interoperable.
FL
When you say you're "getting nothing", exactly what's wrong? No audio? Not finding a control channel/out of range? No TGs popping up as active?
ofd8001
Louisville, KY
Posting screen shots so we could look, might be helpful. Also let us know what system you are looking at programming.
22nineline
Sorry guys I thought I had the whole day yesterday to work out the G5 issues but a phone call changed that. Might be able to get back to it later tonight. One thing I needed to do was dpwnload the software since what I had was on the old computer and the new 4.0 is what is on the site now. Can I use that without doing a firmware update on the G5? Or should I find the old software? Kind of like to know it is working before I change too much like the firmware. Thank you
