G5 two tone paging
KO4RJX
Benson, NC
I'm debating on ordering a G5 to carry for the FD but have been courious about the two tone paging aspect. Can any one provide a video of a G5 activating for a two tone alert?
Sent from my P008 using Tapatalk
sfd119
I guess I don't have a video of it, but it works just fine. In fact, I can have multiple tones on one "knob" and what not. I use it as my primary pager now instead of the department one.
ZapBugs
Warning... 2 tone is on an analog freq only. Not enabled on p25.
So for me, it fails miserably because the analog paging system is very weak where I am located.
But the digital signal is very solid but paging is unsupported.
KO4RJX
Benson, NC
We have 5 analog paging sites here in my county so that's not a concern. I was curious if it's as loud as the Minitor, from what I can see it does not have a standard "beep" you find on the minitors
Sent from my SM-G935V using Tapatalk
W2GLD
Michigan
I have both a Unication G5 and Minitor VI here and they are both load; however, the G5 is louder in my opinion than the Motorola VI. As far as the tones, yes, it has the standard Minitor style beep noise that you'd expect but you can also add a host of custom alert tones as well. The biggest thing that I noticed is the tone sampling time on the second tone in the two-tone page. The Motorola Minitor VI alerts almost immediately after sampling the second tone and the alert duration is as long as that tone (say 2 seconds) whereas the G5 sampling time is much longer, almost 1 to 1 1/2 seconds which limits how long the alert tone is. Now, this is adjustable; however, we are finding that some dispatches are cut off in the beginning; so we're still experimenting with this. What Unication engineers should do is fix the tone sampling; I mean if you listen in monitor mode, you'll hear just how long the G5 waits to activate it's alert from the second tone; crazy delayed in my opinion when compared to the gold standard Motorola Minitors... On a positive note, the receiver in the G5 blows away that in the Minitor VI as far as sensitivity; however, with additional sensitivity come poor selectivity; we've had several instances where the G5 falsed on another departments tones; we've never had this with ANY of a our Minitor VI pagers.
These are just my thoughts as we experiment with the Unication G5 when compared directly next to a Motorola Minitor VI and yes, before anyone comments, both pagers are running the latest firmware from their respective manufactures and we've been testing them in real world environment as well as lab environment with a General Dynamics Communication Service Monitor. The hopes is that later firmware will correct a few shortcomings of the G5; it's a good pager, but the problem with the discussions on RadioReference is that their users are looking at this device from a scanner perspective and not what it's original design was for, and that's a public-safety grade pager that give the added bonus of a scanner.
ScanWI
MN & WI DB Admin
Wisconsin
I will upload a video on Youtube shortly of my G5, the default tone is a long tone that can be found in the Minitor, however the Standard Minitor tone is not in the G5 by default.
You can however upload a MP3 or WAV file into the page to use as your tones.
KO4RJX
Benson, NC
That's the main issue I'm running into is most the information I can find is more from the scanner aspect. This be used as my main fire pager. As a captain I have a dept issued P25 radio but don't 1) always have it on me and 2) this would make monitoring our ops channel enroute a whole lot easier.
I also work for 911 so bringing this to monitor the highway patrol is a plus.
W2GLD
Michigan
This G5 will do exactly what you want; basically, at least at the moment we are doing something similar. I have Mode A switch programmed to monitor the two-tone paging dispatch conventional frequency and then when dispatched to a call, I switch to Mode B, which is Project-25 trunked radio system and only scanning the talkgroups related to my dispatch, Mode C is a wider area and so on down the knob sections (example: fire only, then fire & ems, then fire, ems, police, etc). You can also have multiple zones as well for much larger area scanning. Just remember conventional two-tone cannot be scanned with Project-25 trunking in the same selector switch; this is mostly because of affiliation times to the control channel.
KO4RJX
Benson, NC
I've been messing with the programming and so far it appears I can do exactly what I want. I wished it had the ability to decode pocsag alpha pages.
KO4RJX
Benson, NC
Ordered the G5 through Rays Pagers with free shipping. Still interested in the alerting video if you got time.
ScanWI
MN & WI DB Admin
Wisconsin
The Test 3 corresponds to Tone 3 in the pager and so on, sorry I thought about it later. I could have labeled them Tone 1-8 instead of Test 1-8
ScanWI
MN & WI DB Admin
Wisconsin
I am using the newest software. I have not gone through ll the tones before so I am not sure if they have changed.
ScanWI
MN & WI DB Admin
Wisconsin
Not that I know of, I did check the programming to make sure I didn't select the wrong tone set.
