G5 UHF band
ka1njl
Fairport, ,New York
I am interested in picking up a Unication G5 based on the things I have read here on RR and have a question. The specs for the UHF version list four different bands from 330 - 520 MHz. Can the UHF band be changed in software after I own it or is it fixed so I need to be very careful about which one I buy?
ka1njl
Fairport, ,New York
thank you
Thanks for the quick reply. I thought that was the case, it means I need to think very carefully about my needs before buying one.
I had hoped that since the device is an SDR that the band could be changed. On the positive side maybe that means that there are hardware filters specific to the UHF frequencies specified and that can potentially lead to better rejection of unwanted frequencies.
ecarvalho
True. I have the VHF version and before buying had to make sure which systems I needed it for. You are on the right path.
APX8000
Sarcastic Member
AES-256 secured
Also understand that the VHF and UHF versions use an internal loop antenna. The external antenna is for 7/800 only. I don't have any issues receiving trunked UHF systems anywhere inside the County I'm in but if you are looking for out of County coverage it will fade out quicker than 7/800 due to the antenna. On 7/800 even with the stubby I can hear neighboring trunked systems with the G5 in my cup holder and you'll just laugh when you put it up next to a Whistler or Uniden scanner on the same system.
w2lie
New York DB Admin
Long Island, NY
The G5 bands are "hard coded". For the Public Safety UHF, you will be looking for the UHF-D pager, which covers 450 - 520 Mhz. You will not be able to change the band splits via PPS.
