G5 - UHF band
belvdr
No longer interested in living
The frequencies I know I would monitor on UHF analog are in the 453 MHz range, so either range works for me.
Thinking out of the box, though, which UHF band do you find works best for you on the G5: 400-470 or 450-520?
EDIT: I should add that I'm debating between the Phase 1 or Phase 2 model. It would nice to know that if I ordered a Phase 1 model this late in the game if I would get the Phase 2 firmware for less (or free). I know only David can answer that definitively.
Thunderknight
Bletchley Park
Depends on where you live and visit. The higher split if you live or travel near T-band metro areas. The low split if you live near the affected Canadian areas (eg Buffalo, NY) or are a ham (70cm).
belvdr
Travel is generally to DC area and TN. I’m a ham but don’t care about monitoring the ham bands.
troymail
Silent Key
Yup - depends on where you are (or will be) and what you want to listen to. From my experience, most of what I'd want to monitor is 380s, 405ish, and 450-460. Of course, the dilemma is that a tough decision needs to be made. I know there is some public safety on 480s (west coast at least)...
I think the offer right now is (was? maybe expired) if you buy a Unication, you'll get the Phase 2 for free... I'm not sure what you mean by debating between the Phase 1 or Phase 2 model. Phase 2 is the same radio - just a firmware update (eventually). The Phase 2 firmware upgrade is reported to be an (up to) $150 option....
belvdr
I was referring to pre-ordering the phase 2 model, because the price is the same and includes the phase 2 firmware. If I order the phase 1, I get the radio sooner, but may also face another charge for the newer phase 2 firmware.
Thanks for the tips. I'm leaning toward the 400-470MHz model
troymail
Silent Key
Ah - I understand now -- my opinion? Worth the wait....unless they later give it out for free to everyone....but my crystal ball isn't working.... :D
IAmSixNine
Dallas, TX
Does your crystal ball have the latest firmware?
Is it plugged in? Batteries charged?
Do you have all the control channels programmed in? secondary ones as well?
Try moving the crystal ball to another location to help rule out RF interference.
troymail
Silent Key
Ah, I didn't think to check that it was plugged in.... lemme give that a shot... I don't think moving it around will help (I might drop it).
:cool:
belvdr
You're lucky. I wish I had a crystal ball. All I have is this 8-ball that keeps saying, "Ask again later."
