1. Add each frequency to your profile in PPS #2I'm sorry, I wasn't very clear...
I have 5 conventional UHF (452... MHz) frequencies I want to scan. How can I have the G5 scan those, they are simple analog frequencies.
I do appreciate the responses
JohnnyDollar2 hit the probable reasons for out of range.Thanks, Troymail! That did it!
I have one P25 system I can enter into my G5 under a G4 codeplug, but when I enter the same P25 system under the G5 codeplug, it goes into and stays in "out of range". (I have a few other systems that work just fine) It is the Macon/Bibb co P25 system (Phase 1) (until late October, when it goes to Phase 2)
Anway, any ideas?
For analog, you should be able to simply enter your frequencies in Step 2 and then skip directly to Step 5 and create a zone/knob position for those frequencies using "Monitor Mode" as the option.Hi Guys,
I also am a little confused on programming my G5 for conventional analog channels.
After a little stumbelling I have successfully programed a couple of P25 trunk systems.
Now I am trying to program about 15 conventional analog channels for the surrounding area fire depts.
My problem is I enter all the freqs. in the conv. list in step2,move to step 3 and it asks for protocol type.
The choices are no setting which gives an error to set a protocol, and a few having to do with tones, and P25 conv. and P25 trunking. I am not looking to do tone alerts or anything else but scan these analog conv freqs. If I put in 2 tone in step 3 to move on to step 4 it then asks for tones. If, and when I get to step 5 I choose normal scan and I don't see any freqs. listed to add. I have read the previous posts but still not getting it. I would have thought analog conv. would be the easiest to program and sure it is, but some guidance from you G5 owners would be appreciated. That and some better explaining of the features and how to program this great radio on Unication's part would certainly help. I have read the user guide in the software, watched the programming webinair, and read the pop up descriptions in the software but still not getting it. Thanks for any replies.
Chuck
Should I use Protocol CSQ for a CTCSS?IF it's like the G5 VHF version you make your list of frequencies in #2 in the PPS under the Conventional or UHF frequency setting at the top. You go through steps 3 and 4 and in step #5 YOU add your trunked Talkgroups AND UHF to the ZONE knob positions. After you're done with the Trunked Talkgroups you need to make ONE of those square a CONTROL box for the other *up to 16 knob positions where you have the UHF freqs stored. *light blue box* in ConvZone #3. That box controls ALL of the CSQ boxes with ONE frequency you see in the yellow boxes. Each of those freqs are in MONITOR mode. ONE for each knob position in your ZONES. *mine say CSQ in the photo. OK?... now what? I made the 3rd Zone, FIRST knob as my control for all the Conventional frequencies. Use NORMAL scan or Priority scan to ADD the KNOB positions to your control. The instructions say, use NORMAL or Priority scan to scan up 16 knob positions. It's like ONE controls the other 16 UHF/VHF set to monitor mode. With each new frequency you add, you have to go back to the CONTROL box and add that new knob position so it can be scanned like a list. One thing, when you program the pager and expect to see it scanning the UHF list? you have to make sure you click to the CONTROL knob to that UHF/VHF list so it will work.
It took me awhile to figure it out but I scan 19 or 20 VHF knob positions now for one of my counties. I put that control box in the first Knob position because it's easier to change to it that way when you change zones ON the pager itself. If anyone has an easier way to add ALL 16 frequencies or more to ONE knob position? I haven't heard it yet.
