G5 VHF questions
Haley
I have a lot of questions, but will keep it simple (I am just a scanner guy---sarcasm). But after watching videos, and reading everything I can on the G5 VHF/700/800 radios/pagers I am about to order one.
1. IF I were to use one for Federal monitoring while traveling, by programming ahead of time , common VHF P25 conventional freq. is this possible? Would the VHF model make more sense than one of the UHF models for that purpose? Just seems to me VHF has a lot more users (I do have some local counties also that use P25 VHF.)
2. Am I correct in my understanding, that again if traveling, I would have to have a way to load or program each system, (only able to monitor one at time----correct?)?
3.IF I buy one now, am I understanding the phase 2 (if and when released) will simply be a paid upgrade? Hardware is in the unit, just not enabled. So a software update??
My local systems are all phase 2 able-----but mostly phase 1.
I am new to the Unication pagers/radios, but have been watching in the background for quite some time, just getting a little tired of several scanners, that just are not cutting it. I do realize that the G5 is a pager, NOT a scanner, and has it's own limitations if being used that way.
Thank you for any help, Mike
Thunderknight
Bletchley Park
#1 Yes. The VHF or UHF choice is what makes sense for you. It sounds like VHF in your case.
#2 Yes. You have to program them manually...it's not a RRDB import.But you can program them ahead of time. My G5 has systems from outside the area for when I travel. They are programmed into a zone further down the list. My first zone of 8 knob positions is actually 3 different local systems and 2 conventional groups. One of those trunked systems appears in several knob positions, each with a different list of talk groups.
#3 That is what we believe to be the case. We'll know for sure when it's available :)
troymail
Silent Key
Will answer what I can based on reading and my playing with a G4 and the programming software....
Since it's not an all band scanner, you'll have to decide which model (bands) you want more than others. Some folks have bought multiple units to cover different bands. I got a G4 and then started programming some (distant unlikely to be monitored by me) systems and then realized they are UHF -- not a big loss for me but it did identify a slight limitation.
I've programmed many, many, many systems into my configuration and programming to the radio. I can travel and just switch to a different zone to hear other non day-to-day (travel time/road trip) systems I've programmed.
We've been told it will be a simple firmware update (but you'll have to pay for it from what I'm hearing).
Haley
Thank you both for the very helpful answers! You put to rest any reservations I had. Now to get it ordered, thanks again Mike
scan18
Honoka'a, HI
Quick question before putting this thread to rest, as I am pretty much in the same situation and just ordered a G5 myself. Before it's arrival, I've downloaded the PPS software and started planning out the knobs and zones. I'm assuming when I get it I will need to apply the latest firmware, is the update done within the PPS software or do I use that executable in the other zipped download? I didn't really see any details in the other zip file and launching that executable didn't really tell me much, but I'm assuming obviously it's because I don't have the unit connected yet.
Sorry if the process is already laid out in another thread, I did some searching but was unable to find firmware update procedures other than the steps to email and obtain the download links.
troymail
Silent Key
My G4 came with the current firmware (I think it was release late last year). You may not need to update it - although I too at some point need to understand that process (come on Phase 21)
scan18
Honoka'a, HI
You're right, I think it was from Oct 2016 so it may already have that installed. Thanks!
