The G5RV was designed as a 20m antenna with a little gain that matches to 75ohm coax and it just happens to work fine on 80 through 10m although 80m is down a bit. The G5RV JR is half size and would work best on 10m and is useable 40 through 10 or even 6m and 40m will suffer a bit.
The critical length of balanced line on either antenna only comes into play on the one band the antenna was designed for and all other bands the antenna is a random doublet with a chunk of balanced feedline. If you connect the balanced line directly to a tuner it will be an efficient antenna on all bands within its useable range but when you attach coax you incur some major coax losses on most bands, especially the lowest.
You might look into an antenna called a ZS6BKW which is a modern day computer designed cousin of the G5RV that actually has a good match to 50ohms on 40, 20, 17, 12, 10 and 6m without a tuner. This means it will not incur the same major coax loss compared to a G5RV. It also works about the same as a G5RV on 80m with a tuner and its 94ft long with about 40ft of critical length ladder line depending on the type used.
You can bend any of these antennas somewhat to fit your property and if you like operating on 40 and 80m you really want the larger size antenna rather than a G5RV JR. Here is one of the many sites with info on building a ZS6BKW.
http://www.w5ddl.org/files/Zs6bkw_vs_G5rv_20100221b.pdf
I used to use G5RVs a lot until I discovered the BKW and now use them in many locations and am very happy with their performance.
For most people these types of antennas will be mounted mostly horizontal from 15 to 30ft in the air and they work great for NVIS on 80/40m and also work DX just fine but the higher the better for that.
At one location I have a ZS6BKW at about 25ft height and a DX Engineering 43ft vertical with a significant amount of ground radials and the 43ft vertical works better on 40 and 20m DX but the ZS6BKW is much better on 80m local or DX and better on 40m local and sometimes better on other bands depending on the direction. If I could keep only one antenna at that location it would be the ZS6BKW.
The 43ft vertical cost a couple of hundred bucks and the ZS6BKW was maybe $25 in parts.
prcguy
