Gains with Marginal Height Improvement?
emsflyer84
Central NH
Hey all, just curious if you think it would be worth upgrading my antenna for more height. I'm running a Diamond X50C2 which is 5.6' tall. I'm basically maxed out with my mount as far as just raising this antenna and I'm already reduced my signal loss as much as possible with the shortest coax run I can manager, etc. Wondering if a different / taller antenna would be beneficial if it can only be marginally taller (within a couple feet). Thoughts on this? Should I just ride it out with the antenna I have? Thanks.
prcguy
Taller with everything else the same usually means more gain at the horizon.
