Galveston ferry
kmartin
Riverside, Texas
So yesterday i created a DMR system for TXDOT using the Vhf frequencies mentioned in previous post and FCC database. The TRX-1 doesn't require frequencies to be put in any specific LCN. So i put on record and noticed only 1 TG was being used. I checked my recordings this morning and found while most of the conversations are encrypted not every conversation is encrypted ! Some are in the clear
And they were definitely ferry operations. I would submit what i found but i believe it would be rejected without proper LCN ?
If someone in or around or even visiting Galveston , and has time with a Uniden scanner could figure out the LCN they could post it ,
However if this system doesn't require the proper LCN then i will post it
kmartin
Riverside, Texas
151.00250, 151.15250, 151.24250, 151.37750 that's all i have
There are other frequencies on the FCC database but not sure if they are part of this system
Talk group i found is 16777215 DMR
rattlerbb01
TX/LA Database Admin
Boerne, Texas
Is it a capacity plus system with a rest channel buzzing every two seconds? Or just conventional repeaters or simplex?
