AZScanner
Post above that Placebo effect only.
Not yours.
We still see Garble as noted on first note - so guess can not read...
Appreciate inputs and as noted this is-not a Fix All only testing...
Bill
If the scanner reads the bandplan information from the control channel (hint: it does - Uniden's digital radios have done this since the x96D), then changing it on the scanner makes NO difference whatsoever. You might as well see if the radio works better if you place a jar of Skippy peanut butter next to it or not. In other words, what you're changing isn't even LOOKED AT when the scanner is scanning a P25 system. Hence, the term "placebo effect" applies.
What you probably WILL find however is that you've messed up NON-P25 trunking systems by tinkering around in there. I don't know as I haven't tried this and don't plan to. The scanner is working fine for me as is.
-AZ
