From reading your posts, it seems like you are a bit fixated on the 40 meter antenna being the cause. Don't assume that's the only possible cause.
Christmas lights? At this time of year? And they're never LEDs, right? Oh, wait...."Might be a neighbor with noisy Christmas lights."
"Installation courtesy of Grinch Electric LLC"Christmas lights? At this time of year? And they're never LEDs, right? Oh, wait....
It could be damaged.
However, for it to still work when you are close enough, the receiver is probably swamped from noise from something else.
For both of them to suffer from this at the same time, it suggests a common noise source.
As several people have pointed out, something changed, and RFI is a very likely and proven source.
You need to do some basic troubleshooting. None of us can do that for you.
Figure out what circuit breaker the garage door openers are on.
One at a time, shut off the -other- circuit breakers in your home. If/when you find one that resolves the issue, start looking at -every- device that is plugged into that circuit. Don't overlook anything, and don't assume something can't cause interference.
I've had cheap USB chargers in vehicles cause a lot of RFI and interfere with tire pressure monitoring systems. It might be a USB charger in one or all of your vehicles causing this.
Don't rule out devices at your neighbors homes.
Don't run out and buy all new garage door openers, or call in a repair service without doing some basic troubleshooting. Often, these things are a simple cause and easily fixed.
I am guessing you live in an area where there are military exercises from time to time. One just ended, they picked up their commo toys and went home.The garage doors openers are back to normal, operating properly as they did before. As quickly as the receivers went deaf, they can hear again. I never did find the source of the problem.
Using my RTL-SDR and tuning from 300-400 MHz, I found them @ 309.5 MHz. I was expecting to see something else on the waterfall but the only signal present was the door opener transmitter. Not much noise at all from 300-400 MHz actually.
The dead Vizio soundbar ... that too did not emit any noise (that I could see) from 300-400 MHz. I expected it was the culprit by the test proved otherwise.
The neighbors to the immediate left and right of me did not have any garage door problems while mine was acting-up. So the problem was isolated to my house. Again, nothing new in the house, the same bulbs, electronics, and everything.
I am glad that they are back to an operational state and still wonder what the root cause of the problem was.
