GATRRS (West Texas)
KE5PL
Midland, TX
All have moved over. I will go see if that is something I need to submit. Gomez is now in wide area trunking. Thanks!
KE5PL
Midland, TX
Any update on Gomez Peak being connected back to GATRRS?
Gomez affiliated 10/24. Microwave had to be reset for Big Spring. Should be on for all of those thousands of Howard County users that were unable to communicate. But at least we can all hear Val Verde and Maverick SO off of Site 90.
lhillin
Van Horn
I live in Culberson County, about 47 miles away from Gomez peak. I have a BCD 996P2 scanner. My antenna is a mounted about 35 feet in the air. I have no trouble picking up the Reeves County SO conventional frequencies. I understand that they have a repeater in the Gomez peak area. I currently scan conventional systems. I would like to start monitoring GATTRS, but I am unsure if I would hear anything on the sites closest to me. I am soliciting suggestions as to which sites and talk groups I might listen to. Thank you.
KevinC
Other
Super Moderator
Home
The link to Big Spring is down, and the link to Andrews has degraded. Guessing those high winds have reoriented some link antennas. I believe the sites have been posted on RR. Prolly under GATRRS. Still no movement on the Odessa 700 and Orla sites.
Any update on the 700 Odessa site or Orla?
rn1nduk1
Texas
Idk of orla. Too far for me. I have not decoded any site in midland/Odessa in a while since was not catching much in talkgroups of interest. Some day I may decode and see what control channels show for sister sites if pops up.
rn1nduk1
Texas
Went ahead and turned on scanner to decode. Hitting Gardendale, Midland 800 and Odessa 800, no other site link shows. Best guess in no Odessa 700 site is up or linked.
KevinC
Other
Super Moderator
Home
Anybody run PRO96Com or UniTrunker in the area? That should show any new sites and the control channel frequencies.
slayer7303
McCamey Texas
im in upton county....have been catching a lot of chatter on the TxDOT talkgroups, McCamey, Pecos county, Ector county, Terrell county and Ward county....all so seen a few new unknown talkgroups pop up...cought someone try to do a coms check with Upton county so. ill have to check my logs to get more info.... all this of the king mountan repeater
KE5PL
Midland, TX
Odessa 700 installed, but dark, awaiting bandwidth upgrade. And a tower mounted preamp. Sources say mid-March 2020.
rn1nduk1
Texas
Odessa 700Mhz Machine up.
Per Pro96 Control Channel Decode
FileVersion:8
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 13E
System Name :
WACN : BEE09
Tower Number (Decimal): 1-92
Tower Number (Hex) : T015C
Tower Description :
Control Capabilities : Data,Voice,Registration
Flavor : Phase 2
Call Sign(s) : WPTZ776
Timestamp : Tue Jun 16 13:29:48 2020
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
181,"T0151",13e,"03-2081",155.30250,""
183,"T0153",13e,"03-1687",154.31750,""
190,"T015A",13e,"03-0475",151.28750,""
191,"T015B",13e,"00-1109",857.93750,""
