GD-77 how to program
Hudson, MA.
How do I connect to my PC and not brick my new radio? Want to program it for local repeaters, and FRS/GMRS/MURS recieve. I REALLY don't want to brick my new rig.
kayn1n32008
ØÆSØ
Sector 001
Make sure you have drivers for the programming cable installed. Read the radio and save it. Create your code plug and write it to the radio.
jaspence
Michigan
Since this is a new experience for you, I would just try some analog frequencies at first. DMR requires many more steps and will take time to learn. The links below are a couple of sample code plugs. I learned by trial and error because I was into DMR early, but studying a code plug should at least give you an idea of what it should look like. You will also need to check and see if your repeaters are Brandmeister or DMR-MARC, as the talk groups are not the same. A visit to your local radio club meeting is also a good way to start.
Radioddity GD-77 Codeplug Added – G7RVH
https://www.shawngarringer.org/2017/11/07/gd-77-cedar-rapids-dmr-codeplug/
kg6ood
GD-77 Private call
Fellow HAM operators, I need help in my GD-77 as my first DMR radio. I was trying to connect to openspot but when I transmit is said "private call" how can I change that to the actual freq I'm transmitting to? Any help is truly appreciated.
