GE MPA Programming
W3AWF
Chester County, PA
I have a GE MPA UHF that I need to program. I have read that I need an interface box in order to program it. My question is can I use my RIB box for programming my Motorola radios with the MPA?
"Interoperability is not a luxury, it is a necessity!"
dsw760
You can buy a programming cable here RFguys.com - GE M-PA M-PD MPD MPA MTL P400 VHF UHF Programming Cable no radio interface box needed. You will need a computer with a DB-9 (9 pin) serial connector or a DB-9 to usb adapter..
