General encryption question.
JStemann
SE Indiana
This question popped in my head a few days ago and I thought I'd ask the experts. Can a radio Moto (xtl or xts) contain multiple encryption keys? For example Counties A,B & C use different encryption keys, but a state officer travels between the different counties and also talks to the drug task force which uses a different key.
As a follow up, assuming a radio can have multiple encryption keys, is there a limit? Also, can (or are) the various keys associated to specific talk groups or are they basically active all the time?
Thanks,
Jeff.
RKG
Boston, MA
Short answer:
1) Yes.
2) Using ADP: 8. Using UCM: varies.
3) Assigned per "conventional personality."
esfd283
The radio must have Multikey feature set. I believe its a flash upgrade if the radios don't have them.
mikewazowski
Staff member
Central Ontario
You can slave a specific key to a personality or let the user select the key. You can also have the radio check for the matching key when receiving a transmission and automatically select the appropriate key.
Most multikey radios support up to 16 keys. The newer APX line can support up to 32.
JStemann
SE Indiana
thanks again, everyone. As I was typing the question, it seemed like the radios "should" be able to support more than one, just didn't know for sure. "should" and "do" are sometimes miles apart.
jeff.
XTS3000
Actually the APX7000 can have a max. of 128 hardware keys! Wow.
