Hi i have just some basic questions i would like to ask to clear up some issues i have.
#1 Can i use a pigtail splitter to power a LNA with bias tee or do i have to use a cat tv splitter?.
#2 Would i loose more db with a regular splitter than with a pigtail splitter?
#3 What brand of splitter would you recommend?
#4 Is OP25 the best option for a pi 4?.
#5 What makes a scanner like a sds200 different from a couple of SDR dongles, with the sds200 i can only listen to one thing at a time correct? and with a sdr dongle i can hear just one thing at a time so just based on that there wouldn't be no need to invest in a sds200 would their?
#6 What is the difference between this Link and a regular cat tv splitter?.
#7 What do you think about using 100 feet of KMR240 coax cable for a scanner?
#8 On tv splitters like a 3 way splitter i see 2 ports say -7db and one port says -3.5 db why is that?
#9 Does a J pole antenna need to be grounded?
#10 And finally a question about this Link between that and a regular LNA what would be the difference, would that item be a good thing or a bad thing?
Please i am very new to all of this so if my questions seem a little dumb thats why, regardless thank you for responding.
