I borrowed a friends PSR800 to see if it would work where I live. The scanner had apparently not been updated since new and did not have the system my county uses in the library. I used it for a day or two and I could receive some audio on the systems he had programmed. I installed the EZScan software and copied the data from the scanner. Then upgraded the library from RR.
When I write the new library to the scanner and did an update from library, it stopped receiving on the existing systems. I created a scanlist from the new library for a system closer to home and it while stop on a TG, show 4-5 bars signal, the system, TGID etc, I get a click and no audio.
Any help is certainly appreciated. (I haven't told him yet!)
