- Joined
- Mar 3, 2024
- Messages
- 30
Is the 125AT hard to program? Anything I won’t be able to get other than encrypted ? Thinking about pulling the trigger just don’t want to waste the money if it’s just going to set quiet on the dresser you know?Unless you want to listen to any of the above for your county you should not need any digital scanner. If you are interested in listening to the ones in the above post you will need a SDS series scanner to deal with the simulcast in your area. If you are not interested in digital talk groups you should only need an analog scanner to listen to the conventional frequencies in your county. A Uniden 125AT portable scanner should cover your needs very easily if you are not interested in digital or or DMR talk groups. As for your scanner apps it really depends if you want control over what you want to scan. Hope this helps.
