I've been using regular scanners for around a year now and currently have a 325p2, 15x and 75xlt. I've been wanting to get into SDR but I'm not exactly sure where to start. I looked at some of the pages on RTL-SDR.com and I understood some of it but I still have some questions.
The main system I want to monitor is the Oregon SW-7County System (Benton County & Scott Mtn. sites) which is P25 Phase I. I also would like to monitor the OR Statewide System (Scott Mtn. & Wipper Hill sites) which is P25 Phase II. But, the SW-7 system is definitely the most important for me. Aside from that I also listen to a lot of VHF (mainly 150+ MHz). Not monitoring the analog stuff on the SDR isn't a biggie for me since I wouldn't mind keeping that on my Uniden scanners.
1. Are the RTL V3 and V4 the options I should be looking at? And what are the differences between them?
2. What are some of the advantages and disadvantages to certain software options?
3. How does scanning/monitoring work on said software options? Would I be able to program any like a traditional scanner or does it work differently?
4. Would I need to use two dongles for trunking? I've heard of this before but what exactly requires this?
5. What would be a decent simple way of setting up the antenna? All the antennas I have are BNC. Two are rubber ducks, one is an extendable from the 15x and I also have a cheap VHF UHF 800 mobile antenna from amazon that has a long cable and I mainly keep setup at my window. Would that last one be able to work with the dongle if I just had a BNC adapter for it? I ask because my computer is underneath my desk and while I do still pick up the system well on my 325p2 if I put it around that area, I'm sure that could still cause problems if the antenna was under my desk. I also don't feel like setting up an entire dipole antenna (not yet at least)
Thank you in advance
