i for the life of me can't get unitrunker to read anything from the xt.
You will need to do the following:
A.
Configure Your Radio
1. Connect computer and radio with the supplied data cable. This may require a serial to USB adapter if your computer does not have a serial port.
2. Enable CC data output on the radio.
3. If you have not programmed the system into the radio, follow the radio's front panel menus to create a new system, add a new site, and add the control channels to the site.
4. Select the pre-programmed system and hold on the control channel.
B.
Configure Unitrunker
1. Configure a new receiver within Unitrunker. Set the model, type ("Inline"), role ("signal"), port and baud rate. Your radio's default baud rate is 115200 bps for the front data port.
2. In the Unitrunker receiver panel, set the run state to "Running".
3. Make sure the receiver is still set to hold on the control channel.
