DMJR318
Is it possible to use the mast (from the ProComm PC-SGM/BN glass mount antenna kit) on a NMO mount? Do they make anything for converting it?
Thank you!
Thank you!
Awesome - Thank you for the information. Since I only listen to the frequencies between 151.000 - 160.000 (maybe 450.000 and up at a later time) Which antenna would you choose?The glass mount antennas are usually designed around 1/2 wave antennas. In the case of that glass mount scanner antenna, that's a complex thing.
Taking the whip off that and putting it on an NMO mount would be best done with a matching coil. Challenges would be:
Which matching coil? Usually they are designed for one band.
What is the whip diameter and will it match up with the 0.100 whip mounting cone that is on top of the NMO coil?
Usually those glass mount "30-1200MHz" scanner antennas aren't good at much other than one or two bands. If you already own the Procom antenna, and feel like blowing $50 on a Larsen NMO coil, you might have something that works well enough for what you want.
Larsen NMOWB150BCO - Coils
NMO Coil Only. 135-174 MHz, Use with W490 or W490B Whip.theantennafarm.com
Or, you can get a professional antenna that's actually designed for VHF, UHF and 7/800MHz band and know that it'll work correctly. It's cheaper than buying a Larsen NMO coil on it's own
$39.95:
I'm running this same antenna on my work truck connected to a Harris XL-200 mobile radio on VHF, UHF and 800MHz work stuff. Works very well and is a very durable antenna. It's on top of a Ford F-350 4x4 service truck that's been up some overgrown site access roads and taken a real beating.EM Wave EM-M43002 - Triple Band Mobile Antennas
Tri-Band 150-162/450-490/763-870 MHz IP67 Rated Roof Mount Antennatheantennafarm.com
$36.95:
No spring in the base, so might want to be careful where you mount this on the vehicle, but this has been a really well respected mobile antenna in the scanner community for a very long time. VHF, UHF and 7/800MHz.Tri-Band 150-165, 450-470 & 806-940 MHz Mobile Two Way Radio Antenna Scanner
Tri-band antenna covers 150-165, 450-470 & 806-940, 100 Watts, Whip Length 16.5"theantennafarm.com
$55.95:
I've got this antenna mounted on my personal truck. Performs very well. Spring on the base, so just fine on top of a full size truck. I've probably put about 50,000 miles on that all over the western USA without any issues, even some off road, low parking garages, finding a few tree branches and some large bugs in Texas.Mobile Antenna Tri-Band 150-165,450-470,700/800MHz Larsen NMO150/450/758
Tri-band antenna covers 150-174, 430-520 & 750-870, 100 Watts, Whip Length 16.5", NMO (Pogo Contact)theantennafarm.com
As far as my mount - I am going with this mount (Third Brake Light Antenna Mount - 2019-2024 Ford Ranger) with the BNC connector.
I have consulted with a shop that does radio installations, they are hesitant because of all of the electronics that runs along the roof panel.I know ease of install is often on the top of most hobbyists list when it comes to antennas, but there's two issues to pay attention to with those mounts:
1. They put the antenna back on the very edge of the ground plane (roof) of the truck. That will result in a lopsided ground plane and make the antenna directional towards the rear of the truck. You might not care, but it's a lot of money to spend on a mount to have a compromise like that.
2. There's reports of those third brake light mounts leaking. I've heard it many times. Not sure if it's an installation error or just a design flaw.
I know many don't want to do any permanent modifications to their vehicle and drilling a hole in the roof. But a $359 mount is expensive and comes with some compromises. A good radio shop can do a properly installed NMO mount on the truck roof that will work better, look better (my opinion), never leak, and cost a whole lot less.
Your truck, your choice, just consider your options.
A simple 1/4 wave VHF antenna will work very well on those VHF frequencies, and will actually work pretty well on UHF, as a 1/4 wave VHF is also 3/4 wave on UHF. I've run those on dual band radio setups in the past and they work well. Plus the 1/4 wave VHF antenna is inexpensive and pretty low profile.
$13.95:
$19.95:
Larsen NMOQC 136-512 MHz Field Tunable Two Way Radio Antenna NMO Mount
136-512 MHz Field Tunable 1/4 Wave,Gain (dB) Unity, Maximum Power 200(Watts), Whip Length 20" - 1/4w Antenna with Makroblend Polymer Base.theantennafarm.com
Personally, I'd go with the Larsen tri-band I linked to in the earlier post. That'll let you use the capability of your scanner, and they aren't that much more expensive.
Yes - I have that fear about the 3rd brake light mount, but I have heard good and bad about it.
I was also looking at the NMO fender mount, but I am concerned about the chafing paint. If I went that route - which side is better (drivers or passenger)
What about the small windshield mount dipole antennas?
I figured now I have it hardwired; I want to do the antenna situation correct.
Thank you!
I am a DPW worker and I want to do this right.
What's your feeling about the RG 174 cable?
Best advice is do not spend a fortune, for receive you will not notice a difference between a $50 and a $200-300 mobile(I have had both). just get good quality.
