GMR-1 (AMBE derivative) codec
246tnt
Hi,
I'm looking for a way to process audio from a GMR-1 (Thuraya) network. I know the codec is done by dvsinc and based on AMBE, at a 4kbps bitrate.
From the specs :
The speech encoder takes 16-bit uniform pulse code modulation (PCM) samples as input. One frame of encoded speech consists of two quantizer-frames, which each contain 80 bits. The encoded speech at the output of the voice encoder is delivered to the channel coding function defined in GMR-1 05.003 [2] to produce an encoded frame consisting of two quantizer-frames, each containing 104 bits. The vocoder therefore produces a gross bit rate of 5,2 kbps where 4,0 kbps are used for voice data and the remaining 1,2 kbps are used for error control.
The error control is known. So what's I'm looking for is how to convert the 80 bits (48 first class bits per quantizer-frame and 32 second class bits per quantizer-frame) into audio and vice & versa.
Any help is welcome.
Cheers,
Sylvain
246tnt
Does anyone know how to contact the mbelib author ? That looks like my best shot ...
