Hi all, newbie here. I am preparing to install a GMRS radio in my automobile. Said automobile does not have a steel roof, rather, a molded plastic composite, (2024 Bronco). The antenna mount will be mounted to a plastic accessory that is not naturally (DC) grounded. My question is: Should I, or do I have to attach a ground strap from the body/chassis to the antenna mounting bracket. The antenna uses an NMO mount and I see that there are raised "scallops" on the t-nut part of it that I assume are designed to penetrate paint and such in order to be grounded? If I do have to use a short ground strap, I have read on the interwebs that a ferrite bead should be used to "isolate" the antenna? any direction would be greatly appreciated!
