GMRS Antenna location
gatekeep
FAIL 01/93
New York, NY
Sorry, misunderstood the comment myself. He said LMR and not LMR-400, so I honestly thought he was talking about the radio lol. Land Mobile Radio....
Anyways, I am using LMR-400 per the recommendation of numerous people and it is only 40' worth for a base station. I will be hitting repeaters, but I am NOT using it for a repeater physically.
LMR-400 at 40' is perfectly reasonable. The losses will likely be insignificant for base operation.
srbecker58
Amherst, NY
Awesome! Good to hear and sorry for any confusion. Had me worried a bit lol. The LMR-400 wasnt very cheap but from what I was told and read it would more than do the trick, so I spring for it and installed most of it last night. I just have to punch through the wall and install the antenna.
Do you recommend I install the SWR meter full time in line and suffer whatever losses come from it and its extra connections or just check my SWR and then take it out and run directly to the antenna?
I am a lineman for the county.
No need to keep it installed. Use it to test after you install, then remove it.
The only real reason to keep it installed all the time is if you suspect your antenna or feedline will take damage.
